Main issues with claw v liquid ring vacuum pump
I am considering evaluation of replacing a liquid ring pump with a claw pump for a new build project. I would hope (expect) to reduce overall costs by using a dry claw pump. Ie no seal fluid system, no cooler or coalessor or seal fluid pump.
The only draw back of claws i am aware of is the ability to handle liquid. Therefore you require a pre-demister (i think) or liquid KO drum ?
I believe energy usage are comparable ? (and both can use a VSD ? or is this untrue
any advice or links would be apperciated..
