Surface to solid
Surface to solid
I have been sent a file from a vendor and the format it's in is unusable basically it manifold but not a solid it's simply one surface, is there a tool to convert this to a solid?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Surface to solid
3 general fault(s) found.
No invalid edges/faces found.
1 open surface(s) found.
I beieve it started life as an ProE part.
1 open surface means there is a hole some where. If you click on "Open Surface" in the Results list it will higlight to show you were the hole is. You can also click on the General faults to see where they are also.
Hope this helps.
Murph.
