water and oil
water and oil
I noticed that when sample is being taken from a wellhead when it is diverted to test separator that it runs pure water for not less than 5mins before oil will appear but this doesnt occur when it is flowing into high pressure separator.Can anyone explain why?
RE: water and oil
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
RE: water and oil
In your case the new pressure results in water flow blocking oil flow for about 5 minutes while the pressures find a new equilibrium. This means to me that the volumes in the test separator are not representative of "normal" production. This is a problem if the wells have different ownership and different responses to the pressure change. If all the ownership is the same and every well responds about the same then it only matters to the reservoir engineers (who don't believe there is a problem with the data they are provided anyway) since the well production is always an allocation of physical sales based on well tests.
David
