Carbon
Carbon
I'm a mechanical engineer but I am currently serving in the U.S. Army. After we come in from a field training exercise our machine guns have a lot of carbon build-up. To help accelerate the process of recovering our weapons I would like to use a hand held wire disc to remove the carbon. The piece of the gun that I would like to use the wire disc on is steel. My question is: What type of wire disc should I use to remove the carbon without damaging the bolt?
RE: Carbon
What about the metal coating (black phospate)?
RE: Carbon
When I was in the US Army, we had brass brushes to remove carbon deposits from the internals (like bolts).  I would recommend brass, since it is softer than steels, and already has been tested by the US Army.
Cory
RE: Carbon
I also think a soft metal is preferred.
What does the US Army recommend?
Thought about a SOS pad? If it gets cooked on stuff off the pot, maybe carbon off your weapon?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Carbon
bigTom,
Check with Brush Research.  I have used their products and expertise in the past for several different purposes and found them good to work with.  Google 'em.
A second option might be to contact someone like Olin who makes a lot of gunpowder.  I'm just guessing but they would be likely to have a solvent or method worked out.
Griffy
RE: Carbon
What weapon are we talking about here?  Wouldn't you remove the bolt prior to cleaning?
"Art without engineering is dreaming; Engineering without art is calculating."
RE: Carbon
The weapon that we are cleaning is a 240C machine gun, and yes the bolt is removed for cleaning.
RE: Carbon
Depending on the degree of hardening of the build-up, I've used an assortment of 3M's ScotchBrite industrial abrasives (plastic scouring fabric) and assorted other knock-offs.  They're used in metal finishing industry for everything from rough removal (i.e. in polishing operations) to micro-polishing.  Depending on the grade, it can be quite aggressive and may take off the base coating material.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
www.profileservices.ca
RE: Carbon
At my army service, ages ago, in the middle of nowhere, I was using tooth polish paste because it was  available,you know...smile, boys...
m777182
RE: Carbon
I kind of wonder about
oven cleaner, the kind
that you do not have to heat
the oven.
RE: Carbon
Oven cleaner! Interesting, it might be worth an experiment to see if it works.
RE: Carbon
What's the matter with CLP (US Army Cleaner Lubricant Protectant) and brass brushes?  If you want to reduce manual labor, use a wire wheel brush with a drill.
Cory
RE: Carbon
bigTomHanks,
Thank you for your service
Joe
RE: Carbon
I would not go for oven cleaner.  Very caustic.  Probably would strip the finish and pit the base metal.
