Has anyone had experience with Airpinch pinch valves
I am in the market for replacing a few manual ball valves with a valve that could be operated remotely with some sort of control. Pinch valves seem ideal for the application. I like what I have seen from http://www.airpinch.com but I wanted to see if anyone else has had any experience with them.
Thanks in advance
Thanks in advance
RE: Has anyone had experience with Airpinch pinch valves
Pinch valves are well suited for fluids containing particles. Ball valves will probably last longer on clean fluid, probably _much_ longer.
Notice that pinch valves are designed to make replacement of the core easy. There's a reason.
Mike Halloran
Pembroke Pines, FL, USA
