Swing bolt suppliers for pressure vessel covers
Hi everyone,
I am new in the field of Pressure Vessel design, and our company is in the design process of some small vessels.
I need to find an outfit that can supply swing bolts (or eye bolts), of different lenghts (I need between 6" and 7" long from the center of the eye), either 3/4" or 1" UNC threads, and that can certify that the bolts are made of any of the SA materials listed in Section II (ideally SA-193-B7 or similar).  I see these bolts everywhere in different designs, but I have been searching for suppliers on the web without luck.  Could someone suggest one, or a few?
Thank you very much in advance.
RE: Swing bolt suppliers for pressure vessel covers
Not sure where you are but I work for a UK manufacturer of special and non standard fasteners and turned parts. We are involved in export all around the world. We stock B7 as standard and can make eye bolts
check out our website www.hydrobolt.co.uk
Kath
Try Kenneth G. Lilly Fasteners, Inc.
www.kglilly.com
Cheers,
George
