void criteria for solder metallization?
I am looking high and low through IPC, ANSI, and every spec organization I can use to find a good reference for metallization quality standards.  My eyes are going buggy.  Specifically, I am interested in specifying the plating void criteria (prior to solder) for metallized areas that will have components and/or a component soldered to them.
Anyone out there have any leads (no pun intended)?
Don't bother with the standard ANSI/IPC J-STD, already been there 100 times.
