Synthetic oil and static electricity build up.
Hello, electric guy on the loose in the oil fields...
I have had quite a few recent experiences with ball and roller bearing problems - all seem to be related to the swithing from mineral oil to synthetic oil.
There are also other "funny" phenomena that seem to be coupled to synthetic oil. Powerful electric charge build-up and subsequent discharging through filters, plastic tank wall, across ceramic sealings destroying the sealing surfaces etcetera etcetera.
I have very little knowledge about oils. Does anyone with a better understanding have a good explanation to this? I know about the extremely low conductivity of synthetic oils, but is that alone the explanation? What can be done to reduce the problem?
Gunnar Englund
www.gke.org
RE: Synthetic oil and static electricity build up.
Charge is created when two molecules with differing affinity for electrons are first in contact and then separated. Once the charge is separated then there are forces that will try to put them back together. So flow will create charge but it must be fast enough to keep the charges from recombining. Any conductivity in the liquid will help recombination. You are dealing with charged particles and like-charges will repel each other and opposite-charges attract.
In a tank the charge will be higher at the outside surfaces because the charge in the center is repeling other charges. If the tank is conductive the charge will flow to the wall and to ground. In a non-conductive tank the charge will concentrate at the wall. If a grounded object is outside the wall the charge will concentrate near this object because the charge in the tank attracts the opposite charge in the grounded object. The non-conductive tank is basically a capacitor and if you move a grounded object closer to it you increase its capacitance and the voltage in the tank will go down (if charge is constant). If the ground is moved away the voltage in the tank will rise.
Charged liquids can and will move so the charge is not really "static".
Remember that an electron-volt is a unit of work that corresponds to an electron falling through a potential difference on one volt.
Most liquids are conductive enough that one does not observe the effect of charge separation. In conductive pipes and tanks charge usually does not stay separated for long.
Is there a specific problem you need help with?
The oils I have come in touch with are 220 Cst synthetic oils and also some lighter grades. The ball/roller bearing problems are 220 Cst central lubrication applications in gears. We know that we have some electric activity coming from the motor (VFD fed and capacitive coupling from stator to rotor/shaft) but that did not cause any problems when there was mineral oil in the lubrication system. We now seem to get a problem and we are not sure if that is because the synthetic oil produces a thinner oil film (with a lower break-down voltage, and hence EDM in the bearing) or if the problems are "helped" by extra charge separation in the bearing oil.
Most observations speak for the "thinner film" theory. But the oil guys keep telling me that a synthetic oil shall have a thicker film than a mineral oil with the same viscosity. Especially when running at elevated (+70 centigrades) temperature.
So, I do need some views on all this. And also things that I may not have considered.
Gunnar Englund
www.gke.org
So, that part is rather well understood. It is the paradox that we have with seemingly more damages in systems with synthetic oils that we do not understand.
Gunnar Englund
www.gke.org
http://www.fiberglasstankandpipe.com/static.htm
Tom
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
I think that the opening clause should be changed from "...fuels that may accumulate electrostatic charges because of their relatively high electrical conductivity" to read "...fuels that may accumulate electrostatic charges because of their relatively LOW electrical conductivity"
It is the low conductivity that causes the problem.
Gunnar Englund
www.gke.org
