How to create own line type in AC 2006 ?
Hello Everybody!
I have certain problem! How to create own line type in AC 2006 without using text file. I want to create my own line which included triangle on the base of continous line.
THX for responses!
RE: How to create own line type in AC 2006 ?
the help in AutoCAD will guide you through it
"Everybody is ignorant, only on different subjects." — Will Rogers
zuber27,
Take a copy of your ACAD lin file. This generally is located in the program. take note of it's location so you can rename the old one as ACADlin.old. Take the copy and make your adjustments. Place it at the end of the file.
Namdac
