Exploded View in Six Directions
Good morning, I have a 2" hex block and in each of the six flats I have a mated part and I tried to use exploded view to explode each of the six parts, but when I tried to explode the parts in faces that were not at 90 or 180 degrees the part did not move straght out from the surface but rather in angled directions. Is there a way to make SW project each of the six mated parts out 90 degrees from the face of the hex block? I hope this is clear, but if not I will try to explain it better. Thank you in advance for any assistance that is rendered.
RE: Exploded View in Six Directions
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP1.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
http://designsmarter.typepad.com/jeffs_blog
Are you certain that the parts to be exploded were mated such that their centerlines were normal to the hex faces? If they were, I'd report this to SWX as a bug.
