Pipe column baseplates
I am designing T-post pipe supports with pipe columns. I am looking for a design reference for designing the base plates and anchor bolts which are subject to axial load and overturning moments. Does anyone know of a good design reference?
RE: Pipe column baseplates
For round sections, the general assumption is that the actual dimension of the baseplate for sizing the plate thickness is based on 0.8 x OD of the tube.
Dik
DaveAtkins
