Transparent Rubber?
Transparent Rubber?
Transparent Rubber?
Hi guys:
I'm looking for a material in an application that must be somewhat "stretchy" and spring back, like rubber, but is optically transparent (not translucent).  It can be thin and doesn't have to stretch a whole lot, but more than solids like lexan or polycarbonate.  Is there such a thing?
Don
Kansas City
RE: Transparent Rubber?
Like clear plastic hose?
bk
There are transparent elastomers.  For example, Bayer produces a thermoplastic polyurethane (Desmopan) that is transparent.
Cory
Urethanes are your best bet.  There also are some vinyls that might work if you don't need too much streatch.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
in more than 30 years I learned that if something difficult
perhaps you can step back and take an other look:
Perhaps there is a an other way...
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
