AutoCad2007, Problem with object snap
I've got a problem which I've never had before.. When I write for example "tt" or "from" in the command window it says following:
"Command: tt
Unknown command "TT". Press F1 for help."
Command: from
"Command: _from
Unknown command "FROM". Press F1 for help."
And it is like that for most of the buttons in Object Snap.. It's a little bit annoying when I need these tools.
Anyone who knows how to fix the problem?
Or is it just to install AutoCad again? (As I said before, haven´t had this problem before...)
carlorjan (AutoCad 2007)
"Command: tt
Command: from
"Command: _from
RE: AutoCad2007, Problem with object snap
in 2004 it's the same. I think that's general. ACAD needs a "real" command like "_line", etc... first
Lothar
ADT 2004
ACAD 2002
It´s the same if I write the whole command or if I press the button for it.. So the whole palette object snap seems to be wrong in some way..
/co
What Exxit means is that you use the FROM while in another command eg Line, etc...
"Everybody is ignorant, only on different subjects." — Will Rogers
OSNAP is NOT used on its own. You won't get a proper response to your inputting the osnap, if a command isn't ALREADY RUNNING, and ACAD waiting for your response to the running command's next prompt.
I know I went a bit long, but you'd be surprised how many "experienced" Cadders, (NOT JUST ACAD !) don't have a handle on this critical issue! I hope this helped.
Good luck !
C.F.
