What would you want to see in a specification for a dc-dc converter?
If you were a customer, buying a custom made dc-dc converter for an application, what information would you want to see in an outline specification? By "outline specification", I mean the kind of thing that would come along with a quote, before a final system design had been agreed.
I am writing such a specification, but it is my first and I am not sure what level of detail to go into. For example, it seems obvious that I would include the input and ouput voltage and current requirements, but should I include percentage voltage ripple and EMI (I have no idea what the EMI will be like yet)?
Thanks for your help.
Best regards,
BPELEC.
RE: What would you want to see in a specification for a dc-dc converter?
Gunnar Englund
www.gke.org
Output: 28 Vdc @ 5amps
The converter must use a transformer, and the primary and secondary sides are therefore isolated.
Input voltage range, minimum to maximum.
Output regulation under load change
Output regulation under input change
Behaviour under short circuit: shut down, burn out, blow up, etc.
Why not pick a manufacturer datasheet for a similar product from one of the numerous manufacturers: Astec Standard, Power One, Artesyn, Vicor, etc and see what they include. That will give you some idea what you need to achieve and what you need to show on the datasheet.
Sometimes I only open my mouth to swap feet...
I would go further to find the data sheet of a device made by a likely company you might want to use. If you generate the spec from their original specs, it will greatly reduce your expense because they will have a solid clear feel for what you want and will immediately be thinking of how to tweak an existing device to meet your needs. This will probably knock 50% or more off the "otherwise" price.
Keith Cress
Best regards,
BPELEC.
Input voltage range.
Output voltage tolerance and regulation.
Minimum load. Maximum load.
Ripple at minimum and maximum load.
Current limit, overload capability.
Efficiency at selected load points and input voltages.
Output impedance (over a frequency range).
Transient load response. Both applying load and releasing load. Overshoot in the latter case may be very important.
Isolation voltage between primary and secondary.
Capacitance between P and S. Also leakage current (if for medical purposes).
Input current waveform is probably not a problem - but nice to have in spec.
Temperature range storage and working.
Thermal resistance.
Vibration.
Humidity.
Dimensions.
Weight.
Price.
I have probably forgotten a few things. I hope that others will fill those in. Do study the data sheets from competition. That will give you some hints.
Gunnar Englund
www.gke.org
Keith Cress
Gunnar Englund
www.gke.org
You left out "Approvals". Another reason you may want to use a tweaked off-the-shelf model as you/they could probably just ride thru on some/all of the approvals.
Keith Cress
Gunnar Englund
www.gke.org
