Point creation from text file
Hello All,
Learning the GSD workbench and at a point where I need to create a series of points in 3D using XYZ coordinates. Is it possible to read points from a text file into CATIA V5?
CATIA V5 R14
Windows XP SP2
Scott.
CATIA V5 R14
Windows XP SP2
Scott.
RE: Point creation from text file
Catia Design|Catia Design News|Catia V5 blog
Here is an extract from the beginning of that Help information:
Thanks for the tip - but it is too complex for me.
Is there not a method whereupon I can type coordinates into a text file to create a curve??
Scott
Read the help suggested, take the example excel file, and replace the data in the file with the one you need.
you can ont only create the points, but also create the spline through them.
Thanks all for the advice - very sound advice.
