Backfil Material
Backfil Material
I will be backfilling a trench around a 7' deep basement wall in Southern Ontario and need some advice. A french drain will be laid at the bottom of the trench.
The soil in this area is clay like and holds on to water, shoud I discard the earth removed and backfill with a different soil, or mix the current soil with gravel or sand and then backfill?
Would appreciate your thoughts on this.
Bob
Bob
RE: Backfil Material
Bob
