Catia unattended install
Is it possible to install catia unattended by modifying some file on windows by copying the contents of the the
cd onto the hard disk. if so how?
RE: Catia unattended install
Ben Loosli
Sr IS Technologist
L-3 Communications
One company that I worked for was doing Ghost images of the whole operating system, with Catia already installed. This, of course, required a separate hard disk for data only.
Catia Design|Catia Design News|Catia V5 blog
There is a lot of information in that online document so I would look there on all the specifics on how to install unattended. I've done it in the past and it is quite slick.
There are several ways in which you can provide multiple end users with access to Version 5. You can:
install the software on each computer directly from the CD-ROM
install the software on each computer by mapping to another computer on which the software has been copied and is accessible.
When setting up the server you can:
copy all the software into the same folder (as illustrated above)
or, given that the software is distributed on several CDs ( 1, 2 ...), copy the contents of each CD into a separate folder for each CD, making sure that the name of each folder corresponds to the CD number ( 1, 2 ...) etc.
The StartB batch command lets you install Version 5 without the graphical user interface.
You can install all Version 5 software except online documentation in batch mode.
Fighter Pilot
Manufacturing Engineer
