Input files and vibrations
How can I save my actions in ansys as an input file? How can I simulate the action of the vibration of an engine placed on a table?
RE: Input files and vibrations
   There is a log file in your work directory, which record almost everything you did in the process. And there is another way to do it. GUI path: Utility Menu>File>Write DB Log File , or 'LGWRITE' command to make a log file.
   For the vibration analysis, you can do a harmonic analysis with ANSYS.
