Source for 1.25" OD 10 spline shaft
Anyone know of a vendor who would stock a 10 spline (involute 30 deg) 1.25" OD shaft? It would be great if they also had couplers or hubs too. I am working on a small custom forward/reverse gearbox and am trying to use quick change rear end gears but am having trouble finding the shaft stock.
RE: Source for 1.25" OD 10 spline shaft
Looking at a couple of brochures I don't see anyone who stocks a spline shaft to your specifications.
Here is a supplier that we used for quick response on specials
http://www.grobinc.com/coldrolled/
Chicago Rawhide used to offer some in their U Joint catalog, offering 6' lengths on a few sizes. Try Hub City Part # 0332-00393, 1ΒΌ-10 spline, only 10" long. Another to try is G & G manufacturing. They have lots of splined hubs, and can do shafting as well.
Russell Giuliano
1.125 is normal for a 10dp 10 tooth 30 degree spline.
I assume this is not what you want.
