starting large 4000 hp electric motors
When starting large electric motors should the motor be at a stand still before starting motor. It is coupled to a ID fan rated at 2.5 MLBSH
starting large 4000 hp electric motorsstarting large 4000 hp electric motors(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: starting large 4000 hp electric motors
JRaef.com
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." Scott Adams
For the best use of Eng-Tips, please click here -> FAQ731-376
As Jeff says. As long as it rotates the "right" way and if you do not have a VFD on it, it os only good for the motor and everything else if it rotates. But has to be same direction as it is supposed to work.
A VFD (probably an MV type with motors as big as this) it all depends. If there is a flying start function in the VFD, it should take care of it. If not, you better stop the fan before starting it.
Gunnar Englund
www.gke.org
As I understand motors, the primary issue with forward rotation is induction generation or back EMF. If the motor is not generating a significant voltage then it is safe to energise it while it is spinning forward.
Capacitors permanently connected to the motor leads may increase the magnitude and probability of back EMF.
Energising a motor when significant levels of back EMF are present is similar to connecting a generator to the line without regard to synchronization. The odds are heavily against you.
Problems with energising a spinning motor with a VFD are a result of VFD capabilities as well as back EMF issues.
Energisation of forward rotating motors without permanently connected capacitors or motors rotating at low speeds should be safe. You can use a voltmeter on the motor leads to check for back EMF. Be aware that the frequency of any back EMF will be a function of motor speed. The voltmeter should be frequency agile.
Back EMF is a serious issue when power is interupted to a running motor for only a few seconds and then re-applied.
For a motor of this size it may be worth the effort to actually check for back EMF with a meter. It depends on the speed of rotation.
respectfully
After that, your limitation is the motor thermal capacity, you have to consult the OEM for verification of the intended motor cycle.
