Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...(I) have been able to get my problems solved from past messages and also new posts that other users have responded to promptly..."
Geography
jjabal (Geotechnical)
9 Feb 02 7:34
I want to determine the value of ks value of subgrade reaction of soil (in situ).
Ron (Structural)
9 Feb 02 9:00
Use plate load test (ASTM D 1196).
coneboy (Geotechnical)
11 Feb 02 20:23
Another option I have used to determine the modulus of sub-grade reaction is to perform a CPT test with shear wave velocity testing. From the shear and compression wave velocity the in-situ modulus can be determined.  There is also a nice method of determining the soil OCR from the electronic cone data.  In the past I have used this approach for designing a RCC parking area and for a monolithic (raft slab) overlying soft clay.
Coneboy
Guest (Visitor)
18 Mar 02 18:15
You can perform Falling Weight Deflectometer testing to obtain the dynamic modulus of subgrade reaction (k).  The dynamic k is usually reduced by 1/2 to obtain the static k.  The FWD is a good choice especially if you are looking at a large area (parking lot) or long stretches (pavements).  This is also much faster than the plate load test.  A good reference (and easy to find) for calculating k is the AASHTO design guide.  It gives an outline of how to use the FWD data.
Ron (Structural)
18 Mar 02 20:09
Unless you have lots of testing to do or the FWD is being used nearby or on the same project, this method is typically cost prohibitive for single point determination of (k).
Great method for lots of testing, but not necessarily cheap.
Guest (Visitor)
18 Jun 02 12:31
I need to know typical values for modulus of subgrade reaction for soil cement layers. Where could I search for?.
Thanks.
mmena
Ron (Structural)
22 Jun 02 22:13
Modulus of subgrade reaction for soil cement will be quite high.  Check Yoder and Witczak for reference.  Likely greater than 500 pci.
I would not design based on k for soil cement, since the layer is semi-rigid.  Consider a three-layer approach with the soil cement as layer 2, with shear and bending controlling in the layer.
Guest (Visitor)
26 Aug 02 9:50
use the plate load test
Focht3 (Geotechnical)
25 Sep 02 15:43
jjabal: What will you do with k once you have "determined" its value?
Close Box
Join Eng-Tips® Today!
Join Us             Close
