rotary motion to linear moving system
hello
I am new to this group . I have one doubt .
I want to transfer rotary motion to a shaft which having linear motion of about 120 mm perpendicular to the axis of the shaft.
i know one option , use timer pulley to transfer rotary motion with spring loaded idler to account for that 120 mm linear .
is this method is correct ?, and any other method exsists?
with regards
jeyakumar
with regards
jeyakumar
RE: rotary motion to linear moving system
In my case the linear speed is ur slow . Linear motion manualy is actuated by worm-worm wheel through a hand wheel for initial set up of the machine .
I cant use motor in guideways because i have to use same motor power for stationary shaft and a shaft in linear motion .
thank u for ur reply
with regards
jeyakumar
