question about attributes
I wanna create a drawing title block which will contain 2x the drawing number on it, one at the lower right corner and the other at the upper right corner. Can I link these two to only one attribute tag? so when I edit it, both the linked drawing number will be updated.
Best regards,
ct
RE: question about attributes
IMHO, there's no way with attributes. Since 2005 you can use fields ...
Lothar
ADT 2004
ACAD 2002
