AutoCad - Weight and Mass calculation
Is there a way to compute weight and mass in AutoCad without having a solid model of the object?  Or do I need to redraw the object in Mechanical Desktop as a solid model and do the calculations there?  Thanks.
Kevin
RE: AutoCad - Weight and Mass calculation
Massprop gives you some properties, but you have to supply the density of the object.  Autocad only does the length units and it's derivatives.
