ASME B&PV SECTION VIII OVERPRESSURE PROTECTION
If a Section VIII vessel normally operates with a gas bubble, but under extreme circumstances can be lined up to fill the tank solid, does one need to protect the tank from over pressure with a gas relief AND a water relief? Would Section VII code requirements for overpressure protection be met if one could provide a gas relief for normal operation and use administrative guidelines i.e., procedures, to ensure that the valve line-up that would fill the vessel solid never happens?
RE: ASME B&PV SECTION VIII OVERPRESSURE PROTECTION
I'd think a relief valve sized for vapor/gas relief would cover the liquid relief requirements, in general.
In any case, as a genereral statement it is probably acceptable to take credit for administrative controls. I would highly recommend the decision to do so be made by a process hazards ananlsys or risk assessment group, not any one individual. Everyone involved in the decision needs to be familiar with the process, systems, equipment, and operating practices.
Thanks for your response!
