Ruston Gas turbine cranking battery
Normally, the cranking batteries in automobiles are VRLA batteries that run about 3years on average and need no water top-up.
How about using Sealed Ni-Cd battery for cranking? The requirement is for Gas turbine cranking with battery size of some thing like 230Ah (Ni-Cd) for two crank capability. The location is in the desert with temperatures crossing 50degC at times.
Appreciate if you can share your opinions / experiences!
Thanks.
Thanks.
RE: Ruston Gas turbine cranking battery
Can't comment about turbines.
sealed cylidrical ni-cads or low maintenance ni-cads has long life and more efficient. but the peak current requirement decides the selection of batteries. Ni-cads are capable of delivering up to 10C rate (10 times of their Ah rating) for about 20 seconds and 25C rate for about 2 seconds. the is no much change in the efficiency of the battery at 50 degree C.
--QA
Sometimes I only open my mouth to swap feet...
( You need 11 x 1.2V Ni-Cd cells to make a practical '12V' car battery. The car system will overcharge ten cells, or die trying. )
( It's a good idea to cover the intercell links of such a battery. The short circuit current of NiCd cells that size is sufficient to melt a dropped wrench. )
Mike Halloran
Pembroke Pines, FL, USA
ScottyUK,
My assessment also is that Ni-Cd are 3times more expensive. But, you know any organisation which specifies Ni-Cd for cranking applications!
The only Ni-Cad cranking batteries I'm aware of are on a couple of fire pumps, and these somewhere around the 60AH size. I don't know why these were originally spec'd as Ni-Cad, but much of this plant was designed by US engineers and we've kinda surmised that the Ni-Cad cranking battery must be from a US standard. If anyone can shed any light I would be interested.
it is mostly used aircrafts, metro tarins etc, due to the requirement of high starting current. presently, SAFT (France) is manufacturing Ni-cad batteries for every application which includes electric cars.
--QA
The main argument in favour of NiCd was that after it had been cold-soaked to something like minus 40 (F or C), you stood a better chance of getting a cranking current out of one than from a Lead Acid battery - and since all our current front-line aircraft were specified in the days when we thought the next war was going to be fought somewhere cold,that's what they got.
A.
