Sheet metal-Feature can not be performed in DUAL VIEW
I am attempting to transfer a hole feature from the primary part to a second part assembled in a floded view. I seem to get the following error: "The Feature can not be performed in DUAL VIEW. Mapping operation failed." Problem i am having is there are 3 seperate locations along the same plane that 2 other hole transfer and hole array worked perfectly fine. Seems its only on the 3rd section.
In trying to locate a different avenue. I tried from the part level and place the holes in both the flat mode and the flat mode. From the bend mode I get " An error occured during the builld of the unfolded pattern". From the flat mode I get: "An error occured during the build of folded pattern. Topological mappinf error !"
Any one with the solution ?
Your only a failure if you quit trying
