Diamond coatings for drill bits
The company I work for requires drill bits to be coated with an ultrahard substance like diamond. The drill bit shape is quite unique so we can make the steel substrate of the drill and send it off to be be coated. Are there any companies out there that would coat these bits?
RE: Diamond coatings for drill bits
htt
htt
http:
(look for their MAXIT coating)
http://www.casidiam.com/index.htm
Cory
Oerlikon Balzers is listed in the links. They have a pretty good review of their product lines on the website. In addition, one of their salespersons will likely get you a more in-depth CD in a day or two if you request it.
http://www.sp3inc.com/
