Welded wire FABRIC or MESH
Is there a difference between the term "fabric" and the term "mesh"? I have always referred to it as fabric, but a colleague suggested that a mesh and a fabric are different terms to be used based on the gage of the wire.
RE: Welded wire FABRIC or MESH
Dik
Wire mesh is also a name for another product with uses unrelated to concrete
http://www2.mcnichols.com/products/wiremesh/
www.SlideRuleEra.net
Not aware of that distinction... I've seen both spec'd to be in flat sheets. My standard notes stipulate flat sheets but have changed the text from WWM to WW Fabric... don't use WWF.
