Wall thickness of a conical component
I have a component that is effectively a conical tube, into which a solid cone seats.
The internal cone has a load on it which is trying to pull it through the narrow end of the outer conical tube.
The outer conical tube has a threaded insert to anchor it at the larger end.
I'm trying to calculate to wall thickness required in the outer component to resist the inner cone pulling through.
Both components are metallic, internal cone angle 8deg.
Tim
Tim
RE: Wall thickness of a conical component
You'll probably need to use Lame's equations if you are using steel on steel.
Cheers
Greg Locock
What I'm looking at is a very similar fibre termination system, compression cone.
Trying to do some analysis of some legacy products.
Cheers
Tim
