concrete core building
I am looking to model a (3) story building using staad|pro. The center of the structure will consist of a concrete core with a structural steel frame surrounding the core. Regarding the center core of the structure, do I need to model this using a shear wall in staad OR do I just fix those points? What would be the best approach about modeling this building?
Also, are there better FEA software's out there for doing this type of building design?
Thank you
Thank you
RE: concrete core building
