Metal-to-Metal Radial Seal I nee
I need a metal-to-metal, static, 10000-psi, radial seal. I have control over the OD dimensions but the 7” ID may vary +/- 1% on diameter, may be out of round +/- 1%, and may be slightly off centre.  Has anyone ever seen anything that might work in an application like this?
RE: Metal-to-Metal Radial Seal I nee
I am not sure of your full application but the link below is for a company which has supplied dedicated seals to high pressure applications
http://www.vectorint.co.uk/
I have designed radial seals up to 60,00 PSI.  We could go higher but have never had the need.
We use a close toleranced metal ring with o-rings.  The o-rings seal up to 1500 PSI.  You must design the ring so that it will expand and fill the gap, creating a metal seal, before you reach the limits of the o-ring.
The equations for the ring are easy to develop and can also be found in any Strength of Materials Text.
JamesBarlow,
The close tolerance of the seal you're describing won't work for me in this case but the o-ring assist sounds promising. Maybe something along the line of a pressure energized U-cup using an o-ring for the initial seal.
Much appreciated.
U cups can take a lot of punishment, but you're talking about a +/- 1% on 7 inches!!! I don't know of any available piston cup or u-cup that can stand against a potential 140/1000 gap under 10,000 psi. Yikes! Good luck. You really do need a custom seal, or tighten tolerances.
