NX3.0.3.2 Taper function
Hi all
How do you draft a wall from a given point, example: say you have cylinder that is 8.0 in dia. and 5.0 tall and I want to draft 1.0 from the top down of the cylinder wall tapering the wall inward. How do you do this using the [Taper] function with in [Feature Operation] tool bar?
RE: NX3.0.3.2 Taper function
Chris Cooper
Senior CAD Specialist
Cleveland Golf / Never Compromise
www.clevelandgolf.com
www.nevercompromise.com
Make sure your selection bar is available so you can click on the center point.
Justin Ackley
Designer
jackley@gmail.com
If you want to taper a face from a point, first you need a point to taper from. The generic case would be picking the bottom corner of a planar face, the picked point will stay associative (for the most part, but a big model change can foul things up). In your example of a cylindrical face 1 inch from the end, you have no existing point to pick. You will have to make your own. Place a point where you want and run through the taper command. I think you will find the results are not what you want. If I read the original post correctly, you want a cylinder with the last inch tapered. What you will end up with is a truncated cone (or full cone depending on taper angle). Why? Because you told it to taper the face - so it tapered the entire cylindrical face. If you want to mimic a chamfer, you will first need to split the face. The split will create an edge, so you might as well use taper from edge.
Justin Ackley
Designer
jackley@gmail.com
That is quite possible, I think we were typing our responses at the same time (notice the timestamps) so I was not countering anything that you have said; I didn't even see your response until after I had hit 'submit'. We'll have to wait for EngMfg1 to clarify what he was after.
Otherwise you would have to do what cowski said and split surfaces, then split line taper, etc.
Justin Ackley
Designer
jackley@gmail.com
If you are looking to learn the taper command, I would suggest extruding a box shape and experimenting with picking different edges and/or points on the box. Hit the help files for split line taper and body taper, they are a bit more involved.
