Rule of Thumb for Linetype Scales for Dashed Lines
What rule of thumb should be used for setting linetype scales when using hidden, center, dashed, and phantom lines in AutoCAD? For example, if I am drawing at a 1" = 10' scale, what linetype scale should I use for a dashed line? Thank you for your responses.
RE: Rule of Thumb for Linetype Scales for Dashed Lines
If you are plotting from layout mode/paper space, you could use PSLTSCALE set to 1 and LTSCALE set to 1 (or less depending on preference).
I typically use about 3/4 of my dimscale. Dimscale = Drawing scale.
Zuccus
