Tube bundle (Pressure drop and heat transfer)
I've been trying to find theory to calculate the pressure drop and heat transfer over a bank of tubes. I want to generate geometry specific friction and Colburn j factor charts (as in Kays & London).
The best source I have is the VDI Wärmeatlas but I don't understand German. Is there someone that knows of a good source?
Philip
Philip
Philip Oosthuizen
Company info:
SteinMuller Engineering Services
http://www.steinmuller.co.za/
RE: Tube bundle (Pressure drop and heat transfer)
Principles of Heat Transfer - F. Kreith & M.S. Bohn
Both discuss exchanger tube x-flows... & both are in English.
BigInch
-born in the trenches.
http://virtualpipeline.spaces.msn.com
There you will find the chart to calculate the Mean Temperature Difference MTD.
MTD=GTTD-LTTD/Log e GTTD/LTTD
GTTD=Greater Terminal Temperature Difference
LTTD=Lesser Terminal Temperature Difference
Luis
