303 stainless steel magnetic properties
Is 303 pearmeabilty of 1.5 realistic screw manhined parts?
303 stainless steel magnetic properties303 stainless steel magnetic properties(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: 303 stainless steel magnetic properties
Bob Ablondi
What the perm is coming to you.
and how hard you work the material.
If the bar is well annealed to start with (<1.02) the it sounds doable.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
You may want to consider sending samples out to a magnetic testing house from time to time.
Bob A
Bob A
Bob
PS
You have helped me tremendously. I have eccommende this forum to my clients and the PMPA.
This temperature will work but may be a little high, so if someone has a properties data sheet would jump in with a clarification.
It is possible that due to the materials thermomechanical history it is slightly ferromangetic. This could be due to retained delta ferrite or some strain induced matrensite. If this is the case then you may be magnetising the material by the way that you handle it.
We manufacture cold finihsed tubing all of the time that has magnetic permiablity above 5, but it must be demagnetised to a specified residual field level.
It is also possible that you have material that is very lean on Ni (to save money) and therefore not real stable. It could be that your machining is working the surface layer enough to make it profoundly magnetic. I doubt this, 303 machines well enough that you shouldn't impart much work.
If the bar is non-ferromagnetic to start with you sould be able to manufacture non-ferromagnetic parts.
Rust never sleeps
