Handling and Transportation of Concrete Coated Line Pipes
Hi everybody
Can you please help me to find a write up on handling and transportation procedure for concrete coated sub sea line pipes? I have surveyed API 5LW (Transporatation of line pipes on barges and vessels) but nothing is expresses on this issue.
RE: Handling and Transportation of Concrete Coated Line Pipes
Though this guidance re water pipes might give you some ideas, there certainly might be more applicable specifications or guidance documents, as I would think offshore oil/gas pipe installations are likely/particularly challenging, and as mortar coating systems might vary some more per other specifications/between applicators, and for that matter pipes themselves differ in diameter, length, thickness, weight, internal bracing schemes etc. It thus might also do well to obtain any more specific advice from the specific mortar coating applicator and/or installers etc. experienced in dealing with such pipes in the field (as one would think they might have the most experience in at least the handling of the coated pipes).
Rusty Henson Pipeliner ..
Needs help with my new project !!
Texas is nice in the winter..
