Acad 2006 - Snap problems
I seem to have lots the nack of snapping correctly. When moving objects with snap on, often if I am zoomed out I get what looks like snap on to where I want (even with the correct snap symbol highlighted) but for some reason the object snaps to something else (invisible). I presume the accuracy setting is set too precise.
Is this correct and how is it changed - if not do you have any ideads as to why? (can it be related to the dimensions of the drawing and the objects used - mostly problems with blocks)
Cheers. Sean.
RE: Acad 2006 - Snap problems
"Everybody is ignorant, only on different subjects." — Will Rogers
I presume when you say snap within blocks you are refering to insertion snap - if not, help. the insertion was on so I'll try without.
Its such a basic problem but it seems to have croped up recently and I am missing the snap quite often now - anyway I'll give it a go - viewres is up to 5000 from 1000.
Cheers. Sean.
Odd that apparent intersection doesn't pick up the invisible intersection points which have been mucking me about - but who cares - I'm happy now - and its monday, which is an unusual combination.
Thanks for your help IFRs.
Cheers. Sean.
