Command line shortcuts wanted
Does anyone out there have a list of shortcuts for the white lower right hand command line.
RE: Command line shortcuts wanted
These are called "power inputs".  That is the Power Input box.
You can find all that you want to know by looking in your help docs.  To get you there faster, search the drive where your help docs are located, for the following file:
basugat0604.htm
Additionally, check out basugat0601.htm through basugat0603.htm for all the rest of the power input info.
Hope that helps.
Catia Design|Catia Design News|Catia V5 blog
Also roll over the mouse over the commands you want and you get all the shortcuts just left of the "Power input mode".
There are some more in the docs like solid7 has mentioned.
example "c:scale planes".
Ashvanth
Those aren't the only shortcuts that are available, and you can't see the really useful ones by mouseover. (like the filtered selections)
Here's another way, Britguy:
VIEW + TOOLBARS + CUSTOMIZE, then select the COMMANDS tab and choose ALL COMMANDS in the Categories section.
You can then scroll through the hundreds of CATIA commands that are available in the current workbench.
If you select a command, a brief description is displayed.
