Preview in Open dialog not showing
When I open a file via the Open dialog box, the preview does not show. Is there a way to turn this on? I know the files have the preview saved because other users have them with the same files. I could not locate anything in the SW help.
Thank you,
Thank you,
Craig Sink
Mechanical Engineer
Force Design, Inc.
RE: Preview in Open dialog not showing
In the 'OPEN' dialog box, is the preview check box near the bottom checked?
Remember...
"If you don't use your head,
your going to have to use your feet."
Is there a way to remove this thread?!?!
Thank you, I thought I had checked that, but....I can't finish...sometimes I just need a 2x4 or two to the head.
Craig Sink
Mechanical Engineer
Force Design, Inc.
I need a 2x4 daily!
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
Don't worry, all your questions have been really challenging. In fact so challenging that we I read this question I assumed you ran into some bizarre issue involving the "preview image". We are all human.
Glad this one is fixed.
Joseph
Craig Sink
Mechanical Engineer
Force Design, Inc.
