Using Min(), Max() in Excel VBA?
Is there a way to make use of Excel's built in Min and Max functions within a VBA program?  I would like the returned value to be stored in an integer, not in a cell.
Dave
RE: Using Min(), Max() in Excel VBA?
Quote (Excel VBA Help):
WorksheetFunction Property
Returns the WorksheetFunction object. Read-only.
Example
This example displays the result of applying the Min worksheet function to the range A1:A10.
CODE
Set myRange = Worksheets("Sheet1").Range("A1:C10")
answer = Application.WorksheetFunction.Min(myRange)
MsgBox answer
