Amplifier Stability & PZ analysis
Hi all,
I was wondering what techniques do you guys use to check the stability of low frequency , very high gain AC coupled amplifier made using Opamps? I ran some simulations for Pole-Zero analysis and the simulator gave output in the form that i never expected....It says "Imag" over Y axis varying from -12.50 to +12.50 and "Real" (rad/sec) over X axis swinging between -3.000T to +3.000T.I expected it to show Gain and phase margins with pole zero location ???.. I don't know what to make of this...anyone?? All my poles and zeros lie exactly at 0 of Y Axis and between 0 to +1.3T (to the right) and this circuit i am so far not able to get it oscillating on board.....I could post a jpg but am unable to find the link on procedure...thanks in advance
RE: Amplifier Stability & PZ analysis
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
Here's the link to the screen shots....Yeah Jim, it seems like Giga, Tera but what does such mega units have to do with phase angle, i have no idea....Look up the image and send me your suggestions....Thanks in advance to all who help....
Are you sure your model component values are what you think?
Gunnar Englund
www.gke.org
Fortunately the simulation package i use has facility of defining miliVolt as "mV" and so on. So there is hardly anything that can go wrong there. Moreover , i am getting perfect outputs for Output waveforms / Transient response and frequency response plots...So component models should be fine....But just still wondering about the G & T units for phase...Thanks for the help
