Split Design Table in Drawing
I have inserted a design table into a drawing. I now want to split it similar to splitting a BOM table. I have tried to right click in the table but do not see this option. Is there a way to do this?
SA
SolidWorks 2007 SP0
SA
SolidWorks 2007 SP0
RE: Split Design Table in Drawing
As far as I know there is no command to do this. This would be an excellent enhancement.
You may have to copy and paste the top half of the design table into your drawing, and then copy and paste the bottom half of the design table. Of course this is not parametric at all.
cheers,
Joseph
A workaround is to make a copy of the first sheet onto a second sheet in the same DT, and manipulate both it to show what you need and then insert both sheets into the drawing.
Each sheet has to be active when closed before inserting into the drawing.
Thanks for the replies and suggestions. Was just as I suspected. I will mention the enhancement to my VAR if they ever call me back today. Another option may be to write a macro to transfer a DT into a general table. That I can split.
SA
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
