Help BOM Format File Syntax
I need to export my Pro/e BOM to a text file for import into excel.  I know I have to create the bom format file and I have some examples of the format script text, but I do not have a description of the script syntax.
Example: %$name[-31s];%material[-9.3s]
Need definitions of each charactor group.
Do I need the section called " .breakdown" or can I use only the summary?
If anyone could send me an explanation for this, it would save me hours of trial and error research.
Thanks.
Chris.
RE: Help BOM Format File Syntax
Serach the PTC website Knowledgebase for BOM format.
This is the document explains BOm formats:
www.ptc.com/cs/cs_25/howto/asm111/asm111.htm
Ben Loosli
Sr IS Technologist
L-3 Communications
Ben,
Yeah, that's my problem--my maintenance has laspsed and can't get into PTC knowledge base.
Chris.
send me an e-mail at
ben.h.loosli
<at>
L-3com.com
Ben Loosli
Sr IS Technologist
L-3 Communications
