Managing subcontractor supply chain for quality
I am a project manager and I am interested in managing subcontractor supply chain for quality in construction. The purpose is finding a method to analyse defects in construction as an aid to decision making in relation to subcontractor supply chain management. Most of the work today is made by subcontractors and the head contractors act as a project manager. I would like to find answers to this questions:
- How can estimate quality cost and non-quality cost?
- ideas for improving relationship between contractor-subcontractor.
- ways for improving supplier gestion.
- Where can I read about this problem?
- Lean Construction and Last Planner can be a solution??
I would like to find anybody interested in this problem to talk with.
Thank you
RE: Managing subcontractor supply chain for quality
Your question looks a bit multi-various. Do you require a quality cost improvement process or a complete construction project management initiative for contractors and subs management?
Greg Akhibi
Clearwaters Consulting Ltd
Thank you for your reply. First I would like to stimate quality and non-quality costs. I am trying to write a matrix with all the costs but I am not sure what quality indicators are the most suitable to control defects and costs in construction. I should be greatfull if you could help me (I am trying to find some technical papers and books but the information I got is not clear). After this I would like to know could I integrate this in a complete project management initiative for contractors and subs management as you say.
Fernandez,
Civil Engineer.
If your quality improvement plan is working well, the COQ should be dropping with time in an operations setting, however since construction projects are usually time-bound and quality requirements for different phases are not often the same, such trending is not possible.
The only way out is to benchmark between similar phases of similar projects, either from your own organisation or your competitors.
While COQ is a good indicator of quality performance, a more immediate indicator is the number of Non-Conformance Requests, NCRs, generated. Quality improvement effort is not intended to identify faults but rather to prevent faults from occuring during project execution, if more NCRs are being generated, it is an indication that you have to go back to the drawing board.
Greg Akhibi
First of all thank you. I agree with you but I think I have a problem with non-conformance requests. I am trying to make a classification of non-conformances and I am looking for all the causes during the process of construction that can cause defects. The problem is how to quantify some of them like waste of time or sales lost by poor quality. I would like to find indicators suitable for measuring all this. Have you got any idea?
Yours faithfully,
Fernandez,
I would'nt consider "waste of time" or delays difficult to quantifying; if a deliverable is towned-down at quality control, the time spent from then on till it finally passes quality control is the delay.
Copy and paste the following link in your browser and read the PDF file hope it helps.
cee.uiuc.edu/elrayes/Time-Cost-Quality.pdf
Greg Akhibi
Thank you very much again.
