Design publications and software for Post Tensioned slabs on grade
My background is in structural steel design and construction management. Need suggestions for a good PT software and design book(s)with examples of post tensioned slabs on grade. It may contain prestressed concrete design.  I am aware of what PTI and PCA have. Any other recommendations? Thanks.
RE: Design publications and software for Post Tensioned slabs on grade
Design of a PT slab on ground is pretty simple. You should not need softwatre for it. Just make sure that you put in enough PT if you want it to be crack free. There are a lot of rumors about cracking in slabs designed by the PTI method and I would think it is caused by too little PT being used.
rapt,
What residual stress have you found out to work out best?  The book I am reading based on PTI recommendations uses 50-75 psi residual stress.  Is this too low?
It looks about right for 75 psi.  As a rough guideline, structural floor slabs (not SOG) have an average compression stress of about 200 psi and SOG should be about 1/3 of this (as a rough start for preliminary design) You need to understand the loading the slab is subjected to and the elastic moments developed.  If the slab is uniformly loaded to say 75 psf, the only (or main) flexural stresses are due to minor variations in slab thickness, moments within the slab due to tensioning, tractions from the sub-base, and variations due to uneven bearing. I would place the strand above the centroid of the slab...but below the top kern, this provides a greater compression in the top fibre.  Minor cracking of the bottom of the slab isn't visible... Friction losses can be assumed to be 0... even for slabs, I assume the losses to be 0 for most cases, the poly sheath has such a low coef of friction.  An oversight on an earlier project I had 300' long strands tensioned from both ends.  When they stressed from the opposite end, with the initial overstressing, there was almost no loss.
Care should be taken to ensure that the slab is not restrained and that the thickness is uniform.
There are ways of minimizing cracking and treating control joints without resorting to PT.
Dik
