PCB trace wiggle antenna
Hi All,
I would like to learn to design a PCB trace wiggle antenna. Does anybody know a good source of reference? Can anyone point me to the right direction? I have access to Eagleware simulation tool.
nstone2k
nstone2k
RE: PCB trace wiggle antenna
I would expect that the antenna is fairly long if you just plan to wiggle a line that radiates a little at each bend.
I've seen something like that but requires stripline with one feed line and an outer groundplane that has a wiggled slot in it.
kch
No it is not a meander line antenna. See Higgler description. Does anyone know a good reference?
Sorry about my previous reply. It looks like the meander line antenna. Do you know anything about this antenna?
Research PIFA antennas and you'll find that design.
kch
