Scaling Center, Dashed, Phantom, and Hidden Lines in AutoCAD
This may be a very basic question, but what are the accepted standards for drawing center, dashed, phantom, and hidden lines? For dashed and hidden lines, how long should the lines be and what should the gap between the lines be? For center and hidden lines, how long should the long and short lines be and what should the gap between the lines be? What rule of thumb should be used for establishing the linetype scale for these linetypes in AutoCAD? Thank you very much for your responses.
RE: Scaling Center, Dashed, Phantom, and Hidden Lines in AutoCAD
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Ben Loosli
Sr IS Technologist
L-3 Communications
