Apron at primeter grade beams
There is an ambiguity encountered in a design review.
A couple of aprons at entrance doors and an apron at truck door are sketched with dowels connecting aprons and the grade beams. The dowels seems not necessary to me. I used a detail before with just a cold joint, the apron slab was 1/2" lower than the grade beam at the interface where a L2x2x1/4 ange was embedded around the grade beam.
From my view, the dowels may have adverse effect when frost heave happens. What do you think?
Thanks for input.
Thanks for input.
RE: Apron at primeter grade beams
Dik
