save Dialog box text is jumbled
when I save the dialog box reads " ????? Part1 ????"
I have tried changing my windows system font. The only thing that was installed on this system prior to the problem was Autodesk True view file viewer but even whan I uninstall that the problem persists.
This problem is only is Solidworks and no other applications.
All other text areas appear fine.
RE: save Dialog box text is jumbled
Make sure the font you selected was a ".ttf" (True Type Font).
I had that a long time ago after changing the windows font to a non-ttf font & all I could see was
h
